fusion
Has anyone used Beet Juice for weight in there back tractor tires does it work , any pros or cons .
When it leaks, it makes a great big red stain. Some tire makers do not advise beet juice as to the reaction to some tires. Weighs less than calcium. Calcium is about 12 pounds per gallon, water is 8.35 pounds per gallon. If all your looking for is dead weight for a FEL perhaps, a 55 gallon drum with a water spigot in the bottom would suffice, rigged up to the 3 PT.
