Company Logo Shop Now
TractorLinks.com
Oil pump rebuild?
54FergieTO30
07-11-2018 20:49:41
Working on a non-running 35 with z134. Is there a way to tell if the oil pump needs a rebuild kit? I have no idea the last time it ran. The engine is getting a full rebuild and I am guessing I need to rebuild the oil pump, but I hate to spend another $80 or so if I don't need to. But then again since I have it torn down to the bare block I might as well go ahead and do the oil pump too.
Advice appreciated.
54FergieTO30
07-12-2018 06:06:25
 Re: Oil pump rebuild? in reply to 54FergieTO30, 07-11-2018 20:49:41
I don't really like how the previous rebuild put the set screw in. Looks like it could spin very easily. I went ahead and ordered a new pump rebuild kit. Oh well its only money :)
Tom h.
07-12-2018 07:34:11
 Re: Oil pump rebuild? in reply to 54FergieTO30, 07-12-2018 06:06:25
Itís not that bad, you will need to tap the shaft and gear together to make it work.
Steve@Advance
07-12-2018 05:19:52
Chances are the pump will have some wear unless it was replaced previously.
It is easy to disassemble and inspect. A shop manual gives the wear tolerances and shimming procedure.
matt from oz
07-11-2018 20:56:10
Hi 54 TO35
Why wouldn't you do the oil pump? You are in there doing the engine why not renew everything and be all good to go. $80 is cheaper than a short lived engine overhaul.
2tractors
07-12-2018 05:31:53
 Re: Oil pump rebuild? in reply to matt from oz, 07-11-2018 20:56:10
One reason would be no increase in pressure. My new rebuild kit had no effect.
