I started this project a few months ago and it kept growing and I kept having less time for it. So today and tomorrow we are getting a LOT of rain so I had a chance to get back to it today.
I already had removed the PTO drive shaft which was NOT a lot of fun with all the snap rings etc. which reminds me I need to replace one I broke.
So today I took apart the input shaft housing and replaced the two seals (main drive and pto). The PTO seal was definitely the culprit, it pretty much fell apart, definitely rotten.
So for anyone who knows they have a trans leak and don't want to be bothered, I'd say now that you have it apart, probably to fix the clutch, it's well worth it to replace the seals. It's a bit more work but I'm pretty confident that in the long run it will be well worth it. Because of this leak the starter and clutch both had to be replaced/rebuilt and had I left it like it was I would have been throwing money down a hole to replace those parts.
Here is before I cleaned up the leftover mess.
And after
And the input shafts and housing taken apart and ready to pop out the old seals. This was the easiest part of the whole job, took maybe 20 min.
And after
