IH756 will not move
old
So I do not know much other then I was asked what maybe wrong with it. Was told it will not move and ya not much to go on so any ideas what maybe wrong or any problem that
are known to this tractor??
THANKS
yea, not much to go on. assuming the engine is running, first question, is main clutch slipping? if not, and it's in gear, next most likely guess is that TA is out along with hydraulic issues. if hydraulics are completely shot, the tractor should move itself in TA low but if the sprag is out and hydraulics are working, it will pull with either the hi or low clutch, masking the TA problem until hydraulics act up. i guess we're also assuming it's in gear.
All the info I was given is it will not move nothing more so yes hard to even say till I talk to the owner of it. His friend told me about it and asked me what I thought. I told him it could be a number of things like the clutch or TA or rear end but hard to say with out more info
Like others and you realize, not enough information. So, I will throw up a guess also and when you get more info you will have something else to go on. I guess the low side of the TA is shot and the mcv pump has not primed up, therefore now power steering either, and high side needs hydraulic pressure. Now, I just thought, a whole lot of those in your country don't have a TA so there goes my guess out the window.
