Farmall F-20 Cultivator
PineKnoll43
New User
I have a 1937 Farmall F-20 with a set of 2 row cultivators and the PTO driven lift. The row spacing is currently set at 40 inches. At the moment, The rear width is 84 inches. The rear wheels can not be reversed to change the width of the tractor's stance because the brake housing gets in the way. Is there anything I could change that would enable me to cultivate 30 inch rows of soybeans?
cast center rear wheels with the rims set all the way in would probably get you narrow enough even if it is not a Narrow rear end. Not sure if 36 inch roundspokes or cutoffs would make it unless it is a narrow rear.
Thanks for your input. I had a feeling that the rear wheels (36 inch round spokes) on it would not allow me to cultivate rows that are 30 inches apart
