Order Farmall Cub Parts Online
1949 Farmall Cub won't start
ctm4003
10-18-2014 09:29:26
Battery fully charged. When try to start, nothing happens. If I hook up 12v booster box, tractor runs as long as the booster box is hooked up and on.
ken house
10-18-2014 15:45:37
 Re: 1949 Farmall Cub won't start in reply to ctm4003, 10-18-2014 09:29:26
clean all electric battery connections; with emphasis on ground cable. remove ground cable from tractor and clean that part.
gene bender
10-18-2014 13:36:25
If you have good connections and read 6v to the coil when engine cranks it will start. Using 12v passes enough volts to make it run.
