You've got a tough row to hoe ahead of you. 660 is not a common tractor. Cabs are not common on tractors of that era.
So, you're looking for an uncommon accessory for an uncommon tractor...
How are your fabrication skills? If you just want "a" cab, you can find cabs out the wazoo at any tractor salvage yard. All you have to do is figure out how to mount them.
One factor you have to keep in mind is that the operator's platform has moved forward on the tractor over the years. A modern cab assumes that the seat is directly above or ahead of the rear axle of the tractor. On older tractors the seat hangs off the back, as far out as over the drawbar. IIRC the 660 seat is still behind the axle.
At some point in time, someone has actually fitted an 86 series cab to a 560, so anything is possible.
Meade Mfg made cab for rear entry tractors. I just cut one up off my 660. Didnt think it was worth saving. WRONG Again Shucks!!!!
I already have a cab on my 560 and 460 so now I need a rear door cab for a 660 I know they are out there it will just take some time to find one
