F-14 with power lift
Oldiron29
This is power lift under seat! I have it working with a 2 way mounted plow, It will set and than lift plow as it should. The problem I am Having is the arms seem to go past the stop position.
I am wounding if the springs are set too tight.
Or should that snap down or up at the end of the 180 degree rotation. Most troulbe some when it is snapped back it hits the plow release so you can not lift it. I need to stop it before that point. anyone else using a power lift on F-12 or F-14 impliments? oldiron29
I have one on my F!$ and a plow to go with it. Its been a long time since I've had the plow on or the unit apart. When you move the lever to rotate the shaft do you leave it in position. I've never seen mine move unless I move the lever. I'm not sure what spring you're talking about unless its on the implement. There are no springs inside the hydraulic unit.
Charles, On this unit there are 2 large spring one each right and left, I beleive they are assist return spring. They mount on the frame foward of the clutch pedal and foot peg. I am starting to thing they are to tight and I need to back them off. oldiron29
