Super C decal location
Could someone tell me the location of the following decals on my Super C #1(Be carful stop Power take off before dismounting tractor)#2 (Be Carful do not make short turns etc.)#3 (Hitch Only to drawbar or front hook and not to tractor)#4 very small (Late A,B,C-V12119) #5 (LH D B-curved decal) And finally #6 O D B It's also a curved decal. Thank you for your help. Basil
#5 and #6 is the same decal. You use one or the other, and discard the one you don't need. It goes by your light switch. The letters L H D B stand for Low and High charge and Dim and Bright for your lights and coincides with a cut out system on your generator. The letters O D B stand for Off Dim and Bright and coincides with a voltage regulator equiped generator. Can't tell ya exact placement of the others.
(quoted from post at 22:39:43 08/07/14) Thanks,
You can try google image search of different views of a tractor to see, but who says those are correct.
power take off goes on the pto shield. Hitch only to drawbar goes on the back of the seat pan. other post told of the lite sw location. Sharp turn wasnt factory. Lots of decals have wrong or extra decals that werent factory and also do not have a complete set like drain for rad,oil level,clean every 40hrs for breather cap and the list goes on. Some put the turn one on the gas tank.Guy Fays book shows the original ones and placement.
