Fast Hitch parts - not a bad buy
couv
bought these items for $ 100 :(2) tractor receiver boxes, (2) points with clamps for tool bar, and (2) points bolt-on style
a nice find
Those 2 receiver hitches with the long curved irons attached are a good find. They are originally from a 100/130/140 Hi Clear and also will fit a Super AV. The 2 little brackets bolted on each side of the receiver hitch would go up and attach to the rockshaft. Did you by chance get the brackets that bolt to the rear drop axle housings ? Those hitches you have aren`t easy pieces to find.
I didn't look for those brackets. This guy probably has some if you need them. His stuff is mostly Hi-Clear
I have that set up on my 140 Hi Clear already, so I`m pretty well set as far as that goes . Was more pointing it out that if you had access to the brackets, it would be worth it to get the complete set up, thats all.
