Where's the radiator drain on a 41 H?
Eric Allen76@ya
06-24-2014 13:37:39
Hey Im sure this is an easy one, but I want to change the rusty mud looking fluid in the radiator of my H for antifreeze, and havent yet found the drain. A quick clue where to look would help a lot. Would you guys recommend a flush, or would that ruin the radiator and make it leak? The tractor sat for twenty years before I got it. Thanks
Eric
wayne in mn
06-24-2014 19:42:04
 Re: Where's the radiator drain on a 41 H? in reply to Eric Allen76@yahoo.com, 06-24-2014 13:37:39
One on the left bottom of radiator; look above the tire. Block drain on left side of engine near carburetor.
Dalex
06-24-2014 18:39:52
Flushing won't damage the rad , but it might expose any leaks it has . Don't you want to know now rather than after you expensive antifreeze in it ??
Eric Allen
06-24-2014 21:26:11
 Re: Where's the radiator drain on a 41 H? in reply to Dalex, 06-24-2014 18:39:52
Excellent point. Thanks guys!
Wild Bill
06-24-2014 14:01:42
there should be a drain passing through the lower steering bolster, below the radiator. I believe its on the left side of the tractor
