Greg K
I have a friend who has a 656 that is dumping hydraulic fluid out of the front bolster. There is a cap underneath that has some o-rings on it he says. He replaced the o-rings and put a thicker gasket behind the cap and it still puked out. It sounds like a stuck bypass valve to me but I don't know the first thing about those tractors. What could be the problem and where would a guy start looking? Thanks.
Find out where the oil is coming from. If it's not pouring out of the top cover, replacing the gasket and orings in that top cover is a waste of time.
I doubt it's a stuck bypass valve, because it doesn't make sense that a bypass valve would vent to atmosphere. Even in the 60's that was a no-no, if not for anything else but the oil was expensive to replace and it made a mess on the tractor.
Most likely the oil is either coming from a blown line, or out the bottom steering arm seal.
No gasket under that cap. Just o-ring. Putting a gasket would lessen the sealing of the o-ring. I has a leaker couple years ago, not pouring it out but leaking, that someone had not installed the o-ring that goes on the sleeve piston rides in. Was able to pull sleeve out a little and put an o-ring on it. Those lines leak more often than anything else.
