Rex Simpkins
Well I found a donor Super C this week and want to get started think hard about how I am going to do it. I have reviewed the post on here and elsewhere but want to do this step by step.
I want to do this the simplest way and it seems like Not drilling a pilot bearing may be the simplest way.
Some have said they used a flywheel from a 504 and pressed in a bearing for the drive shaft to ride in after trimming the drive shaft 7/8".
First of many questions is there anyway the original flywheel can be used instead??
If I have to use a 504 flywheel can the larger 504 clutch be used???
Many more questions to come and I appreciate any and all inputs to my quest.
