Farmall 656 gearshift crosshaft grease zerk---where is it?
Can someone tell me where the grease zerk for the transmission shift cross shaft is on a Farmall 656? The owners manual shows this as a lubrication point, but for the life of me I can't find a zerk anywhere on it! This is supposed to be on the trans. shifting shaft that is behind the steering wheel.
I have a 686 that has a grease fitting right on the top inside the battery compartment below the dash. There is another one on the bottom side of the shift lever.
