(quoted from post at 14:09:57 05/13/14) I like your idea of a little extra lube in the fuel but how much is a touch for a normal mid-size tractor fuel tank of 12 - 18 gallons or so in size, Hal?
(quoted from post at 15:27:38 05/14/14) Just my opinion here, but doctoring up your gas really only serves to separate cash from your wallet.
What exactly are you expecting that tiny bit of oil in the gas to lube on an overhead valve 4-stroke engine?
On a 2-stroke engine it makes sense because the fuel has to go through the crankcase and past the bearings to get to the cylinder.
On an overhead valve 4-stroke, the only place this tiny bit of lube will touch is the protruding section of valve stem on the intake. A fraction of an inch. How much good do you really think that is doing?
The oil burns during combustion, so nothing gets to the exhaust valves.
If you think it's doing something for you, by all means continue, but like someone else said earlier, there is no science to back it up.
(quoted from post at 19:34:16 05/12/14) After you get the stuck valves freed up, the push rod straightened (yes they can be straightened in some cases), and the valve lash adjusted: Consider adding a touch of Marvel Mystery oil, cheap 2 stroke oil, ATF, kerosene, diesel, or even 303 hydraulic oil to your gas from now on into the future.
This modern gas along with tractors that are not used as much as they were used in the past seems to see more stuck valves and bent pushrods.
I add a touch of whatever I have handy at the timefor some extra valve train lubricant.
