farmall super h hydraulic pump
tp
Is there somewhere to buy a rebuild kit for it. It is a stage 2 super with a motor driven pump.
No. The pumps are not rebuildable.
You have to throw it away and buy a new one, unfortunately.
Seals (or Orings can be found at bearing or parts stores with a match up. THe wear is usually on the end plates resulting in gear wear on the aluminum housing internal surfaces. These are not able to be re surfaced and re shaped (way tough to machine and finish) for less than new would cost to make. If just leaking, seals can be found. Jim
