1586 door lock
Dave H (MI)
Would some obliging soul with an 86 series factory cab be willing to take the 8 screws off the door panel and snap me a closeup of a working door lock? Seeing it in locked and unlocked position would be great but any picture appreciated. I had a key made for mine and want to put it together but not sure all the parts are there AND there does not seem to be a way to match the mechanism to the lock in such a way as to allow it to turn. A picture is worth a 1000 words.
On BOTH doors? How does that work? You lock yourself in?
Mine has a rocker switch on the right side and a key switch on the left door. You lock the right door from the inside and then exit left and key the lock. I have to leave this tractor 20 miles out in fields around the county. Sooner or later some little kid is going to f*** up my electronics or worse. Trying to play safe here...if anyone can help me out.
