656 3pt controls
mkirsch
On Dad's "new" 656, the 3pt will not respond to the position lever.
It goes all the way up when the draft lever is moved all the way back, but the relief valve starts squealing as soon as the hitch is all the way up, and doesn't stop. When you release the draft lever, it springs back forward and the hitch drops to the ground.
The hitch has only two positions: All the way up with the relief valve squealing, and all the way down.
Any ideas what's going on with that?
Can you pull the top link plate(like a 706/806)?Or does the whole top need to come off? Just curious.
