Russell Moore
I have tried to adjust the linkage on my shifters and I also adjusted my clutch it got better but it still grinds
if you put it in neutral and let the clutch out then try to shift it into high low or reverse it grinds
once you have it in range if you try to shift from gear to gear it grinds and sometime will not even go into gear
any help or suggestions would be great thanks
