lever on bottom of farmall 300
bill gaw
03-15-2014 14:38:10
while cleaning the bottom of tractor to get ready for painting found a lever in the middle of area under the power take-off drive parts catalog calls it seasonal disconnect coupling shifter my question is it something i should use and why? Thanks Bill
Fudd
03-15-2014 16:46:33
 Re: lever on bottom of farmall 300 in reply to bill gaw, 03-15-2014 14:38:10
If you are not giong to use the PTO, I would disconnect it. Saves wear.
Zachary Hoyt
03-15-2014 15:04:58
Mine went bad on me last summer when I was mowing hay and I had to put a hose clamp on the shaft to hold the collars together so I could get back to work. I need to put a solid collar on it before next summer.
Zach
