1206 tin work
I"m currently fixing up a 1206 that was given to me. I need to fix the left and right panels that say 1206 and the panels that say "Farmall" for both sides. What other IH's can I get these from? Also, where can I get a grill for it?
Well, you're not going to get ones that say "1206" from anything but a 1206...
The Farmall panels from an 806 should fit. You could use International panels from an 856, 1256 or 1456 (856 being most common) in a pinch, I'd think.
The grill should be the same on an 856, 1256, 1456, and 1026. Again, 856 is most common.
Where? Find your local salvage yards.
The radiator side panels from a 806 or 856 will not work. A 1256 0r 1456 will work because they have the flair out for the larger fan and fan shroud.
Steve Smith in Mayfield KY. should have what you need. 270-247-2219. He ships nation wide. He sells new , used and aftermarket IH parts. I have bought a ton of parts from him.
