815 and 1460 Combine Diesel Engines
Lamont
Is there a tag on the engines that tell what they are? Both had two diesel choices as I understand it. The 815 is non-turbo. The 1460 in turbo. Thanks for any help. I got them from combines that were being salvaged. 815 showed 32xx hours. 1460 showed just shy of 4,000 hours. Previous owner had started to scrap them, but I stopped him mid process. Unfortunately, much had already been torched and it was too late to save much.
There should be a flat milled spot on the block where the ID and serial number of each engine is stamped.
