Super C Touch Control lever springs
PADeutzGuy
New User
While I'm waiting for the rebuild kit for the Touch Control itself I'm going through the levers as one side is very tough to move. I see there are coil springs in there, and mine appear to be rusted pretty well. How do they come out? It looks like they have snap ring of some kind? I also can't get the end with the double nuts to unscrew, or is it not necessary to remove it?
Are those springs still available?
Usually spray with wd-40 or something and that will free the lever as it has worked for me got to take time and go easy as those levers on the ones i have worked on the lever was held with a roll pin to the shaft.
Doesn't nesceasarily have to come apart. Lots of penetrating oil, letting it soak, & moving it back and forth should get it freed up.
I've never had to replace the springs. I have had to replace the friction pads. You want them loose enough to easily use but not so loose they won't stay in position.
