Farmall h thermostat gaskets
sony224422
01-12-2014 09:24:54
I am having trouble finding the gaskets I need for the thermostat housing. I have the one that goes to where the two half's meet, but am leaking badly from the one that goes to the head to the housing. I can't seem to find that one
point3dave
01-12-2014 17:31:40
 Re: Farmall h thermostat gaskets in reply to sony224422, 01-12-2014 09:24:54
Hi I made a gasket out of a plastic qt oil bottle for a floor jack 5 years ago still holding. Improvise
sony224422
01-13-2014 09:13:50
 Re: Farmall h thermostat gaskets in reply to point3dave, 01-12-2014 17:31:40
Ordered 7 gaskets for a whopping 20$ shipped to my door. Thanks
gene bender
01-12-2014 12:13:29
If you will look around you can find a couple types of gasket material and thickness will save you lots of order and running around for gaskets in the long run. Loctite Blue and Black are the two sealers you will need.
Dean Olson
01-12-2014 10:31:34
As others have advised make your own. It's cheaper and faster than ordering from a dealer. I buy rolls of various gasket materials and have had no issues.
Old Popper
01-12-2014 11:27:40
 Re: Farmall h thermostat gaskets in reply to Dean Olson, 01-12-2014 10:31:34
For years I have made gaskets out of cereal boxes, or beer cases, for use to hold water or coolant. Coat cardboard with grease from one of your grease tubes and it should seal.
jdleach
01-12-2014 10:25:59
As been said, those gaskets should be available through Case IH. If you don't have a dealer nearby, several of the restoration vendors can provide them.
That said, I was talking to Dwayne at Rustic Red Acres a couple weeks ago, and he stated that many of the older tractor parts are being obsoleted by the company, and there are already a few gaskets that arte no longer obtainable from CIH. In such cases, it would be a good idea to invest in an Exacto knife and hole punch set to make your own.
Zachary Hoyt
01-12-2014 10:08:01
You can cut your own from a roll of gasket paper. I have done that a few times with good results.
Zach
AG in IN
01-12-2014 09:52:45
45102DA is the gasket p.n. for where the two housing pieces come apart to access the thermostat on a Farmall H.
45103DA is the gasket p.n. for where the thermostat housing bolts to the cylinder head on a Farmall H.
Both should still be available from any CIH dealer.
AG
sony224422
01-12-2014 10:36:48
 Re: Farmall h thermostat gaskets in reply to AG in IN, 01-12-2014 09:52:45
You are awesome. How'd you find that? I have all the manuals and everything from binder, I couldn't seem to locate it
And thanks for the other suggestions too I am going to get a roll of gasket maker and some good rtv too
Bob
01-12-2014 12:28:29
 Re: Farmall h thermostat gaskets in reply to sony224422, 01-12-2014 10:36:48
NOT hard to look up on-line.
