Got a 140 tractor that was originally 6 volt with a generator where someone converted to 12 volt alternator. Having that it is COLD outside; I thought I would ask here before baring it trying to troubleshoot.
The alternator is not charging and I don't recall if it ever was or not. I have a good alternator that I can put on it, but my question is.....is the wiring correct? Whoever converted it did this to the original wiring and how do you know that it's correct? If not, then the way they wired it could be the suspect. I have attached a wiring diagram that I have from a Farmall 140 Owners Manual....not sure if it is for 6 or 12 volt though.
Thoughts, ideas, suggestions??
