656 split continued
The tractor is now split from the rear end, with it apart, I tried spinning the gear going to the tranny while pushing in the clutch, I can turn it a small amount in direct drive one way. pulled back it won"t turn over at all just moves a hair back and forth either direction, any clues as to what I need to look at next? Trying to find someone to speak to about it, dealers too busy to mess with it. Kinda hard to explain it on here
Zack You need to pull the Ta out and go through it. That said you should have split it at the clutch first. So pull the Ta housing of the engine and then take the Ta out, take it apart see what it needs. rebuild. When you go back together put the housing on rear end first then back to engine.
