IH 806 forward gears
mark tapey
11-09-2013 07:37:08
My 806 suddenly lost all forward gears but has reverse, however when I was trying to get back to the shop it made some bone crushing noises every so often like a slow gear running into a fast gear? If any one could help I would greatly appreciate the help, I really need her this winter.
Thanks.
caterpillar guy
11-10-2013 07:52:35
 Re: IH 806 forward gears in reply to mark tapey, 11-09-2013 07:37:08
When you get the floor board off it will be the one with the linkage going to it. About a foot wide and 8 inches long front to back. When you pull it off look for the roller that is on the cam. Like said either the rail shaft is broke or the fork. Might also be one of the rollers is missing can let the gears touch. There are 3 rollers . 1 on the cam 1 on the pivot i on the fork.
GeneMO
11-09-2013 16:40:58
I have the entire set of gears hanging on nails inside of my truck shed.
Gene
mark tapey
11-09-2013 18:27:06
 Re: IH 806 forward gears in reply to GeneMO, 11-09-2013 16:40:58
That's good to know, your very kind. Thank you.
pete 23
11-09-2013 13:34:11
Like others said, range cover and side cover off. I am sure you will find the high low fork laying off the shift rail. Either rail broke or set screw or cap screw came out of fork. Couple different styles went into production. Then you may need to pull rear 3rd link cover and long arm reach in over differential to grab rest of rail. If broken it probably will come out the front. But to install a new one, it is from the back. I use a still hose to guide rail over differential. Different ways to do this, what ever work.
mark tapey
11-17-2013 14:10:17
 Re: IH 806 forward gears in reply to pete 23, 11-09-2013 13:34:11
Yep, broken rail. I'm assuming the third link cover is on top under the seat? Could a person machine a two pece rail and get it to go into the front? Was thinking about some reverse engineering for that bolt hole in the shaft, not the best design!
Trying to avoide removing the cab, just getting at this cover was a buga.
Jim Naden
11-18-2013 00:32:40
 Re: IH 806 forward gears in reply to mark tapey, 11-17-2013 14:10:17
The top link cover is just above the PTO on the rear.
A shift rail could be easily made that emulates the rail used in later tractors that retains the shift fork with a small wire snap ring on each end of the fork.
Mark Tapey
11-19-2013 18:58:58
 Re: IH 806 forward gears in reply to Jim Naden, 11-18-2013 00:32:40
Would that cover be on top under the cab rear or should it be right in my face looking at the rear, I'm not seeing any thing that looks like a cover plate on the rear unless its under the third point receiver.
Thanks for the C clip idea, that's perfect.
Owen Aaland
11-19-2013 20:11:14
 Re: IH 806 forward gears in reply to Mark Tapey, 11-19-2013 18:58:58
If you have a two point hitch there will be a cover over the hole just above the PTP. If you have a three point hitch the hole will be covered by the third link bracket. It is held on with six 5/8" bolts.
mark tapey
11-10-2013 08:13:59
Thanks Pete, that's gets me a few steps ahead of any book.
DeltaRed
11-09-2013 12:15:44
Yes.Pull the floor board.Then you can see the range cover.It should be pretty 'selfexplenetory' on how to remove it.Fron the side,the only fork you can see is the reverse idler.But you still need to remove the range cover.And just for your information,the speed cover is sandwiched between the steering support and the transmission.
mark tapey
11-09-2013 16:36:46
 Re: IH 806 forward gears in reply to DeltaRed, 11-09-2013 12:15:44
So it is the cover further back not the one under the steering tower? That's what my frkn book doesn't show.
Thank you so much for your help,.
DeltaRed
11-09-2013 17:49:25
 Re: IH 806 forward gears in reply to mark tapey, 11-09-2013 16:36:46
Yeppers,the range cover is the one under the deck.
mark tapey
11-10-2013 08:09:27
 Re: IH 806 forward gears in reply to DeltaRed, 11-09-2013 17:49:25
Your awesome, thanks a million.
caseyc
11-09-2013 09:48:12
Time to pull the top range cover and see what broke...
Casey in SD
mark tapey
11-09-2013 11:51:18
 Re: IH 806 forward gears in reply to caseyc, 11-09-2013 09:48:12
Ohhhhh man, is that the cover just below the steering tower?
Any way to see the shifting forks from the side ? It just quit without a sound or hickup.
Thank you very much for your help
