paps super a was restored and overhauled 10 or 12 years ago. it has ran great till last year then got worse this year. we use it to cultivate 25 acres of tobacco 3 or 4 times each year. when you first start, it will run like new in third gear. as the engine comes to temp, it looses power and must drop to second. about 30 min later, it has to go down to first and will hardly pull itself. there is no steam from radiator or water loss to speak of. there is a lot blowby out the oil fill cap and hood has oil residue from this. it starts instantly. I have checked timing, done plugs, coil, points, condenser, cap, button. I think its the rings, whats you idea. thanks
