450 Starter
There are several 3 different starter drives on YT parts,Does anyone know the difference.I heard there was an inproved one that suppost to be available. I also see a new one that has a 10 tooth starter.Has anyone used this and is this the newer style drive on it?
The good starter drive is much different than the old one. It has no big spring, only a small easy to stretch return spring. It has power flowing through the shaft to a cushioned pinion, not through the spring. I would use the same number of teeth. Jim
