Craig Cherry
New User
Recently sold my MH33 and purchased a IH 2444 S/N 00838. It seems to be a perfect tractor for small field work, firewood and trail maint. After only a couple of hours of operation the power steering is making a lot of noise while turning and has stuttering resistance. I don't see any fluid leakage anywhere that is substantial.
The tractor has an aux hyd. pump on the crank in front of the radiator and also a smaller hydraulic pump on the right side front of the engine behind the radiator, which I believe is the one for the pwr. steering It also has a large external hydraulic reservoir that runs along the left side of the tractor that is plumbed to the front pump.
I tried searching and reading, but I'm still confused I think. As far as I can understand the fill would be behind the seat and should be about 6" below the plug. I measured it there and it's about 5 1/2" so a little full. However when I remove the plug next to the gear shift I can't see any fluid. I thought that the fluid gravity fed down to the trans. Can someone please tell me specifically what I need to be looking for?
Thanks
Craig
Thanks
Craig
