Anonymous-0
I've searched the archives and found a lot of helpful information to make the swap as easy as it can be. The issue I'm having is I put on a brand new 12v no external resistor needed coil but it will not fire. I tried a couple old 12v coils marked use with external resistor and it will idle but not rev without missing.
When I put the original 6 volt coil on it fires right up and idles well. In neutral it will rev but under load it starts to miss. Do I need to adjust the points or plug gap for swapping to 12v? I'm taking back the new 12v coil in the morning to get another and see if it will fire.
The plugs/wires/points are old but ran fine with 6 volt system.
Thanks for any input!
