How Much Does a 400 Weigh
DelMN
Does anyone know about how much a Farmall 400 weighs? It is a narrow front. I think that it has fluid in the tires and no wheel weights. I have as estimate that the fluid adds about 1000 pounds. Any help would be appreciated.
Thanks in advance.
With fluid I would estimate 6800 lbs. My 450 weighs 6000 with pressed rear wheels, narrow front and fast hitch.
depending on tire size . But just figure on a 1000 lbs a tire . So my GUESSTA MATE is that it is weighen around 7800 lbs. Never go by the SHIPPING weight . Just like my 806 when i bought it was nowhere even close to SHIPPING weight . 806 Diesel narrow ft fast hitch flat top fenders when put on the scales she weighed in at 13750 with loaded tires . The rear tires were FULL of cal. with only about three inches of air space as that showed up when the weather changed and you could see the dew lines on the tires . They must have filled them tires when they were laying down to get that much fluid in them . And the shipping weight for a 806 is around 98-10000 lbs .
You are close on the fluid 14.9 x 38 -67 gal, 559 lbs.per tire and 15.5 x 38 66 gal 550 lbs.per tire. Not knowing what all you have on the tractor I would say she weighs between 6,500 and 7,000 lbs. My 450 with 15.5x38's no fluid with two set of weights on each rear, 84 lbs of weights on front wheels,standard swing drawbar plus costum hitch on front for pushing wagons around and she weighs in at 6,700 lbs..
I have a 3pt and two weights on each wheel and I think it was 6900 at a tractor pull years ago.
13.6 X 38 tires
SDE
My 400 narrow front with fast hitch 14.9-38 Firestone F&Rs not filled weighed 7500 even with three sets of rear wts at our local pull. A couple years ago at the same pull with 14.9-38 Good-Year (the wiggly tread ones-forget their name) it was 7500 with 2 and a half sets of wts. Yes those tires were heavy.
