Adding 3 point to 544
big a
08-14-2013 09:14:18
Looking at a pretty clean, honest little 544 row crop, but just a drawbar. No rock shaft or 3 point.
Never tried to add one on something that had factory option for it. What would it take to install an IH 3 point?
Nebraska Cowman
08-15-2013 03:30:35
 Re: Adding 3 point to 544 in reply to big a, 08-14-2013 09:14:18
I would think an aftermarket 3 point designed for an H or M would work.
Phil Tibbetts
08-14-2013 12:45:44
I have a 544 Hydro junked out because the Hydro was bad. It has all the 3ph setup there if you are interested. Don't know where you are but I am in Maine.
John G. Hasler
08-15-2013 10:39:22
 Re: Adding 3 point to 544 in reply to Phil Tibbetts, 08-14-2013 12:45:44
Do you want to sell any other parts off that 544? I have a gear drive utility but there should be some stuff I can use.
Email is jhasler at newsguy.com
mkirsch
08-14-2013 11:38:40
The 544 is completely different from the 706/806 and other "large frame" IH tractors.
It is actually the same rear end as the 656.
IIRC, the 3pt rockshaft, cylinder, and controls are all in a housing that sets on top of the differential housing, under the seat.
Easiest way to add would be to harvest that housing with everything installed, and transplant it to your tractor.
big a
08-14-2013 09:23:58
This has no fast hitch either. Just a drawbar.
RC Brooks
08-14-2013 09:49:35
 Re: Adding 3 point to 544 in reply to big a, 08-14-2013 09:23:58
AHHHH I see. I had heard the 544 was darn near identical to the 656/756/etc... in many aspects. IF that's the case, you may be able to add the components from one.
Does it have an hydraulics at all?
RC Brooks
08-14-2013 09:22:16
Well, if it's like the 706 and 806, there are the slipins for the fast hitch. I've never really paid much attention to the brackets and such, but it's identical on our 806 and my uncle's 706. I noticed there is a conversion kit offered on here for the 544 as well. This weekend, if your question doesn't get answered sooner, I'll snap a picture.
