Anvilheadtexas
Okay - after hooking up 6 volt positive ground battery to teh battery cables AND NOT the jumper cables, my cub cranks fine. The next step is to wire so I can see if I get spark. I am going to by pass the ignition and ampmeter cause I already dismantled the dash. I only want to see if I can get spark and then maybe fire....then I strip down the rest of the way.
Question...if I by pass the dash, I will wire from the starter directly to the regulator BAT. Then the wire coming out of the regulator from I will go directly to the negative terminal on the coil.
I realize that the current will be constant to the coil so I will build in a temp switch somewhere in circuit.
Any advice?
Any advice?
