Lowering 'H' LIft-All Pump
FBH44
07-22-2013 08:06:55
Question; am ready to lower the Lift-All pump, 1950 Farmall "H", do those two big hex-head bolts, one each side of the torque tube, centered, have to come out? Looks like they might thread right into the pump. I got a toolbox mounted int he way, would be easier to just leave them. Thanks.
BruceS.
07-22-2013 14:14:02
 Re: Lowering 'H' LIft-All Pump in reply to FBH44, 07-22-2013 08:06:55
I use ye ole threaded rod method...very slow but very safe. 4 threaded rods, about 2 ft. long...screw one in as you remove the cap screws that hold up pump. Put a nut 3/8 on each rod first.. Remove all plumbing, make sure the pump drive coupling is in a vertical position so the pump will come down. Open a cold one, and lower away.
Owen Aaland
07-22-2013 13:28:40
The two bolts in the side of the clutch are just plugging holes. As long as they are not too long they will not interfere with removing the Lift-All pump. Originally those holes would have been filled with corks.
I used to remove and install those pumps by myself without any jack or threaded rods. They have gotten a lot heavier today than they were 40 - 50 years ago!
FBH44
07-22-2013 13:03:17
Thanks guys, got it. Yeah heavy is the word...
BigTone
07-22-2013 12:11:44
Yep, just like rusty said...be careful, I'm not sure the weight difference between the H and M belly pumps but the M pump is heavy and awkward and I imagine that the H is not to far off.
RustyFarmall
07-22-2013 10:38:33
There are 4 bolts that hold the belly pump in. They are at the bottom. You also need to remove the fill cap, the lever, and the 3 pipes that screw in from the side. 2 on the left, and 1 on the right. You also need to remove the drive coupling. There is nothing else that needs to be removed.
