Shop teacher 94
New User
Reset the points on the H today. started up and ran great...for 5 minute...then died. Restarted it up and it ran for 20 and died.
Checked the fuel flow...all is good.
Cleaned the screen on the fuel intake...
set the mixture to run a little leaner..
Ran great for an hour at mid idle...
Took it out and started pushing a little dirt around to give it a bit of a work out.
First ten minutes were great. Did what i wanted too...then it started backfiring again and lost a lot of power...
With it still running, i adjusted the magneto to see if timing was off...where ever I moved it just screwed it up worse. so I put it back where it was. Noticed a spark out of the lead wire from the coil to the cap...switched out the wires and now I cant get it to start again.
Any ideas?
Any ideas?
