chad from michigan
Has anyone ever rebuilt a touch control unit? I know you can do they make a kit for the rebuild?
I would like to order just a rebuild kit and not have to order it piece by piece.
Iam still having trouble with my IH-1000 loader on my Super A. It can only lift the bucket half full of dirt about 2 foot off the ground. All fluids are fine. It just doesn't have the lift capacity and I am thinking I should just rebuild the touch control unit. My farmall 100 with the IH-loader has no trouble picking up a full bucket of dirt to almost full lift height.
Do you think it is the touch control or possibly the loader hyd spool controls? The pump did get hot when I had previous problems and I had to replace the shaft seal could the pump be the problem? where should I start?
