560 carb throttle shaft
TedinNE
Neighbor has a 560 gas. When the throttle lever is in the idle position the arm on the throttle shaft points straight ahead in line with the shaft from the gov. Makes if hard to get a correct adjustment. I was sure the throttle shaft arm should point down. Did not have another one close to compare it with. Anyone have one close to look at? Thanks for any help
