Bill in IL
Having some issues with the governor on my 560. I have wide open throttle and low idle any speed in between is really hard to get. It also will not hold or recover rpm when pulling a load.
I removed the governor last night and can see nothing obviously wrong with it. Weights are loose and the thrust bearing looks good.
How much spring resistance is the leaf spring inside suppose to give? It doesn't give much just enough to act as a buffer at full travel. I assume the spring external to the governor does most of the work.
