140HC Steering box rebuild
Anonymous-0
Never been into the steering box on one of these
things, have looked a previous post once I remove
the front axle will everything be obvious to me as
far as breakdown. It looks like my play is coming
from up and down movement of the shaft that the
center steering arm is attached to
Just repaired one last week. Replaced both bearings( one in steering shaft end and one in housing. Bushings were ok.
Complete repair would be 2 bearings, 2 seals , 2 brass bushings, and 1 gasket if gears are ok. Easy fix.
