Order Farmall Cub Parts Online
CUB STARTER WORKS ON BENCH BUT NOT ON THE TRACTOR
lekander883
05-31-2013 04:00:09
6 VOLT SYSTEM.. STARTER SPINS OF THE BENCH. BUT WHEN I PUT IT ON THE TRACTOR WITH GOOD JUMPER CABLES RIGHT FROM THE BATTERY IT HITS THE FLYWHEEL AND STOPS. I CAN TURN THE FLYWHEEL BY HAND WITH THE FAN BLADE... I BOUGHT A NEW BATTERY AND EVEN TRICKLE CHARGED IT OVER NIGHT.. WHATS WRONG..?
T in NE
06-01-2013 07:31:19
 Re: CUB STARTER WORKS ON BENCH BUT NOT ON THE TRACTOR in reply to lekander883, 05-31-2013 04:00:09
When you ran it on the bench, did it slowly wind up to speed, or did it take off instantly, with you having to catch it to keep it from falling on the floor?
If it didn"t try rolling away it needs work. If it struggles to get itself up to speed, it has no chance against a motor.
gene bender
05-31-2013 19:06:41
Just because it turn over on the bench doesent always mean it will start the engine. You could have a bad cable end on either cable. When you enguage the starter feel both ends of the cable and if you find a warm spot that could mean a bad cable on the end of either one and maybe the starter needs servicing.
steve alderman
05-31-2013 07:33:31
are you sure the motor is not locked up if you have a hand crank put it in and then see if you can turn it or maybe give try to pull start I know the cubs with the vertical exhaust get water in very easy and within months they will lock up
Buzzman72
05-31-2013 09:30:46
 Re: CUB STARTER WORKS ON BENCH BUT NOT ON THE TRACTOR in reply to steve alderman, 05-31-2013 07:33:31
My guess is, if he's turning the fan blade to see the flywheel move, (a) he probably doesn't have a hand crank, and (b) if the flywheel is actually moving when he does this, the engine probably isn't locked up.
But both are only guesses.
teddy52food
05-31-2013 06:29:52
Bushings are worn out & the armature locks up when under load.
Allan In NE
05-31-2013 06:15:02
Field windings are ka-puutt.
Allan
Denny ('60 Lo-Boy)
05-31-2013 05:16:58
Clean ALL battery cable connections down to bare shiny metal. Clean face of starter and the tractor to bare metal. You likely don't have a good ground.
