Mounting an L59 mower
Papa's41
New User
Just picked up my first Farmall A and have been looking for an L59 mower, which there seems to be no shortage of. My question is in regards to the mounting hardware. Will the mounting hardware from a Super A or later model work on the Model A? Or will I have to order/locate a mounting hardware specific to the Model A? Any thoughts or a source of supply would be appreciated. Thanks.
A and SA should be same width for mounting bar.
If you go to woods site you can look up how things fit. oldiron29
I think the A used 5/8 inch bolts to mount to the final drives
whereas the superA and later use 3/4. Otherwise, I think the
mounting hardware would work, but the set up for lifting the
mower is going to be different.
Good luck on finding the mount for the A for the Woods hard to find just the mount without buying the whole mower. Lots of the decks are around but the mounts are a different story.
Thank you all for the comments and advice. I'll keep looking. I know they're out there somewhere. Take Care.
