Farmall H Tractor leaking oil out of front of rearend
Mlansing44
New User
Do the bolts that hold the housing on go all the way into the rearend? I have some bolts that seem like they are leaking oil. What about those two pins?
Matt
Matt, that oil could be coming from anywhere and collecting on the pins. I guess you are talking about the drawbar pins. You just have to do some exploring to find out where the leaks are. It's safe to assume that it is leaking from several place though, usually the input shaft seal, the belly pump seals, the axle seals and the pto seal.
I do not believe any of those go into the lubricant. I would suspect it is leaking from somewhere else and collecting there.
