350 Ute power steering leak
farmallmick
05-06-2013 21:50:58
I have a hydraulic oil leak at the bottom of the power steering housing, I believe a freeze plug is leaking/rusted. Has anyone experienced this same leak & if so is there an easier fix than pulling the entire steering assembly out? Has anyone ever used JB Weld or other patch, or replaced freeze plug in place?
Thanks, Mick
Janicholson
05-07-2013 16:46:34
 Re: 350 Ute power steering leak in reply to farmallmick, 05-06-2013 21:50:58
It is a Welch plug used to get the core sand out of the casting. (called a freeze plug but not!)
Draining the unit, then getting the old one out is harder than getting a new one in if replaced. If it were clean and wire brushed, JB weld or putty type fuel resistant Epoxy will work.
Farmallmick
05-07-2013 18:22:29
 Re: 350 Ute power steering leak in reply to Janicholson, 05-07-2013 16:46:34
Jim,
Thanks for reply. Was your suggestion w/ the steering unit in place or removed?
Thanks again.
Janicholson
05-07-2013 18:28:26
 Re: 350 Ute power steering leak in reply to Farmallmick, 05-07-2013 18:22:29
It is a very tight place to work. easiest to fix correctly if removed, but (very but) getting it removed is hours of work. putting it back is hours of work. If you drain it down and get it very dry, a new plug of the correct size, and a dab of the Epoxy, then using wooden shim shingles to wedge the new plug in on top of the old might be a fine quick fix. ( I would try it) Jim
