Fix a flat in inner tubes?
Mark Poss
05-02-2013 16:18:46
I have a small leak on a rear wheel and was wondering if any one has tried fix a flat or slime on a inner tube? Thanks, Mark.
tractor300
05-03-2013 09:05:37
 Re: Fix a flat in inner tubes? in reply to Mark Poss, 05-02-2013 16:18:46
Take it apart and fix it. If you ever fix a tire that has had slime in it you will never use it again. It is as it says, a slimy mess.
mkirsch
05-03-2013 06:07:37
Well first off it would take about 30 cans of fix a flat to even make a dent in a tractor rear, unless you're talking about something real small like a Cub. Not really practical.
If the tire is going flat overnight, or even over the course of a few days, you're wasting your time.
Slime does work, when used to solve the right problems. When the leak is really really slow, for example. People use it to try and fix bad punctures or large cracks, and it just isn't good for that.
Jon Hagen
05-02-2013 20:10:07
Slime does show a product for inside tube tires, not the same product as the tubeless tire slime.
I have not used the tube product.
Bouncer
05-02-2013 19:39:44
They make two kinds of Slime. One kind for tubeless and one kind for tubed tires. I have had very good success with the kind for "tubed" tires. I use it mainly on tires that the beads, rims, or valve stem areas are questionable on being able to be broken down and remounted successfully without having to spend a lot of time or money on. Call me cheap, but sometimes there are certain projects that the profit margin is not there in order to break even. Then sometimes you have to get back to work and have to worry about fixing it right when it's raining and you're in the shop.
CNKS
05-02-2013 18:30:05
Slime is made for small tubeless tires such as those on my riding lawn mower, and bicycle tires. Works well on my lawn mower.
old
05-02-2013 17:07:18
Tried it before and it is a joke at best. May work for a day or 2 but then back to the same problem. Break it down and fix it right and be sure to check for what caused it or you will be doing it again
Hoof print
05-02-2013 16:54:37
Don't waste your time or money. Break it down and fix the tube.
Bill in IL
05-02-2013 16:38:21
Takes more stuff the larger the tire. It does work just not really feasible for a large tire.
It won't work for a nail hole either. It's really only good for slow leaks that you can't find.
kevinj54
05-02-2013 16:24:39
Take it apart and do it right
504-1
05-02-2013 18:37:04
 Re: Fix a flat in inner tubes? in reply to kevinj54, 05-02-2013 16:24:39
Check your vale stems first, it may be the easiest repair ever.
