Farmall H -wristpin bushing size
Restoring Cletrac F with Farmall H Piston-
need to know OD for H Wristpin to see if it will fit Cletrac Rod End Bore thats 1.25 inches-
Does someone know the Farmall H OD of the wrist pin bushing or the Bore size of the H rod end?
Just happened to have my H service manual right here and low and behold, lots of specs but none on size of hole in rod.
The wrist pin bushings are a little bigger than an inch but definitely smaller then 1.25. I don"t remember exactly but the shop only had up to an inch and it was a little bigger than that
