international motor id
nl00sb
04-06-2013 04:09:36
third party image
does this look like a 135 motor that will fit in an farmall c/super c 200 230
El Toro
04-06-2013 17:58:58
 Re: international motor id in reply to nl00sb, 04-06-2013 04:09:36
If that engine doesn't have a clutch the crankshaft would need to be drilled for the throwout bearing. Hal
RPM1941
04-06-2013 09:56:31
The U in IH parlance is Universal, C was carburetor, 135 cubic inches, B was second version. To fit in a C/200 it probably would bolt in but parts list would be all wrong. Would guess that front cover swap & water pump ? might be needed. There was never any info that I ran across from IH that would tell details, only thing we could do was compare parts list on each specific model & check numbers, gaskets were a good clue. This appears to be a Power Unit such as a irrigation engine.
