Install crank pully
To install clean up the shaft end. Put the pulley in the oven for a little while, then while it is still warm tap it on with a block of wood between the hammer and pulley
Those are a press fit and it works best to rig a hy jack and press them on. Some fit a little tighter than others as we are talking about a thous or less for clearence. Dont get the pulley too hot as it wont do the seal any good.
