856 ih hydraulic filter
On the left side of the tractor down below the brakes. Has a tear drop shaped cover with several bolts around the outside of it.
behind an oval shaped cover on the lower right side of the rearend below but forward of the axle. take the bolts out that holds the cover on and the filter is behind it I will try to upload pics from the 856 manual
hope the pics are clear enough to help
