1. Approx how much clearance between top of piston and bottom of head above piston when flat-top piston at TDC?
2. Carbon deposit on top of piston would reduce this clearance, thus increase compression (yes?). That's bad? Why?
3. If everything else in order, should a '50 Cub engine start (no matter how weak it ran) with cyl compression of 70-65-80-75 cold and dry?
4. Is it reasonable that question #3 compression would rise to 90-80-95-90 for wet test? If everything else in order, should the engine start?
Trying to learn in general and in regards to a specific problem - engine won't start.
Thanks
Thanks
